Need help here Quick
BaGearA's Photo BaGearA 17 Feb 2017
My stans tape is to narrow for my rim 22mm tape 30mm rim.
Already tried doing tubeless with it failed miserably.( when mounting tyre and adding sealent the tape just starts to pull away, and yes i can apply the tape right  ) Now what else can i use ? No one stocks 30mm tape localy.
I am not going to use gorilla tape cause it just absorbs all the sealent and my wheel already weighs 100000000kg.
I have A bunch of insulation tape but don't really trust it.
Any ideas appreciated
Reply
Meezo's Photo Meezo 17 Feb 2017
no sorry i can't help
Reply
Khronis's Photo Khronis 17 Feb 2017
I used this , did the job. Just don't know if they make a size for 30mm rims.
Reply
Reply
dirtypot's Photo dirtypot 17 Feb 2017
Try a different shop.  I have two different types of wide tape here.
The Stans tape is rubbish.
Reply
slippery666jesus's Photo slippery666jesus 17 Feb 2017
Modern Bike.
Sent from my iPhone using Tapatalk Pro
Reply
allstar scott's Photo allstar scott 17 Feb 2017
I've thought and thought......
Get narrower rims :ph34r: :clap:
Reply
Jewbacca's Photo Jewbacca 17 Feb 2017
The American Classic rim tape would work.
Made at 30mm for the Wide Lightening wheelsets.
Cape Cycle systems supply pretty much every single bike shop so........
Reply
word
Reply
Long Wheel Base's Photo Long Wheel Base 17 Feb 2017
Before I had proper tubeless rims I also used these. They work well but from time to time the valve starts to tear away from the tube part and no amount of sealant sealed it. Otherwise its a very good alternative to tape.
Reply
The real MJ's Photo The real MJ 17 Feb 2017
Tried silicon tape?
Reply
Myles Mayhew's Photo Myles Mayhew 17 Feb 2017
Do a proper ghetto tubeless setup, if you don't wanna do gorilla tape.
Lightweight tube, cut down the middle, mount tyre with the tube's flaps on the outside then cut off the excess.
Reply
David Marshall's Photo David Marshall 17 Feb 2017
I use this for all the wider rims.  Comes in 25mm or 48mm wide rolls.  I put the 48mm roll onto the lathe, mark out the width that I want and cut with a carpet knife.
Reply
Ampandy's Photo Ampandy 17 Feb 2017
Twice around with gorilla tape and problem solved.
Reply
Odinson's Photo Odinson 17 Feb 2017
Does Gorilla Tape leave sticky residue when removed and is it a biatch to get off?
Reply
Gorilla really is the best...
Reply
