Lefty 29er: what air pressure?
Chain-L's Photo Chain-L 23 Feb 2011
Where can I find setup guide for this lefty: Lefty 29'er Carbon PBR, 90 mm, OPI, Solo Air??
Any help will be great!
CAAD4's Photo CAAD4 23 Feb 2011
PM Kosmonooit. He lives on the left side....
Just Keep Pedaling's Photo Just Keep Pedaling 23 Feb 2011
Probably a stupid question: Do Cannondale make a 'Righty' for left handed people?
AndreZA's Photo AndreZA 23 Feb 2011
Yip, you can get it at the same shop that sells left handed cameras.
splat's Photo splat 23 Feb 2011
Have you got the bike yet?
Isnt there a set-up guide/manual with the bike?
Just turn it upside down..
Didnt get one, will ask tomorrow, but want to ride now!
Edited by Chain-L, 23 February 2011 - 03:45 .
koukie's Photo koukie 23 Feb 2011
Pics of the bike first before any advice can be given... baie jaloers!! :D
kosmonooit's Photo kosmonooit 23 Feb 2011
I got a lot of docs on Lefties @ home will check and revert l8r ..
You set up the sag like any other shock but will find the docs for you
You also need to know about resetting the rollers on a regular basis and of course keep 'em greased.
Edited by kosmonooit, 23 February 2011 - 03:57 .
The Cannondale web site as a lot of technical and setup docs
Generally you adjust the pressure /preload of the shock to get 25% sag - that's the dip of the shock with you sitting on it. Can be measured a number of ways and methods, masking tape and a tape measure helps if you doing it solo.
Also I have found mtbr forums a hive on info - go to the Cannondale section lots of info to search there.
Thug's Photo Thug 23 Feb 2011
I run my lefty if memory serves me right at around 130psi.
Plenty of manuals on the web to download the relevant info.
Edited by Thug, 23 February 2011 - 08:26 .
kennyg's Photo kennyg 24 Feb 2011
I run mine at 110 Psi, the setup guide works on sag, with a 50/50 weight distribution you must have 30mm sag, or something like that.. its in the bike manual...
Chain-L's Photo Chain-L 24 Feb 2011
Did not get a manual, was in a mad rush to get the bike ready and on the trails. Will pick it up later from the shop.
what do you weigh?
kosmonooit's Photo kosmonooit 27 Feb 2011
Here a good doc it's on the 2010 140 Max but should be of some help
